Rhino7, Osnap toolbar select/deselect problem
I can not select/deselect End, Near, Point, Mid, Cen, or Int in the Osnap tool bar. The other selections(Perp, Tan, Quad, Knot, Vertex, Project, and Disable) are working correctly.
I repaired Rhino. Rebooted my Win10 machine…nothing seems to help.
Anyone else have this problem or know of a solution?
Thanks
Hi Steve -
Please run the Rhino SystemInfo command and copy-paste the result here.
Hello Wim,
Rhino 7 SR28 2023-2-27 (Rhino 7, 7.28.23058.03001, Git hash:master @ 4ffc5d7156fbccf2a5d9fcc80e522b3851bc…)
License type: Commercial, build 2023-02-27
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
Primary display and OpenGL: AMD Radeon HD 6900M Series (AMD) Memory: 2GB, Driver date: 11-4-2015 (M-D-Y). OpenGL Ver: 4.5.13399 Compatibility Profile Context FireGL 15.201.1151.1008
> Integrated accelerated graphics device with 6 adapter port(s)
- Secondary monitor attached to adapter port #2
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.5 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.40
Driver Date: 11-4-2015
Driver Version: 15.201.1151.1008
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Users\Dell\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\Karamba3D\2.2.0.171\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\Calc.rhp “Calc”
The driver is almost 8 yrs old, lets start with getting that updated.
Hello Japhy,
AMD considers this a legacy device an so this is the last available driver. This was working. I just started doing a lot of grasshopper work and it stopped.
That video card is not going to perform well.
You’ll want to work in wireframe as much as possible, in one view on one screen.
Let’s turn off GPU Tessellation. If that doesn’t improve things, turn down the OpenGL Level on notch, close Rhino and try again, repeat if necessary.
I tried the vide card settings and none of them fixed the problem.
I found a workaround. My display setup has 3 screens. The laptop screen, and then two other flat panel screens. It works without problems on the laptop screen(Dell Precision 6600) and one of the flat panel screens(a Dell screen connected via HDMI). The problem display(Acer, this is also the largest display) is connected via a DVI port. I found that the toolbar selection on the Acer will start working correctly only if I take the window from full size and resize it to about 2/3 from the bottom. This same reduced size screen will stop working if I move the window such that bottom of the window is as far to the bottom of the screen as possible. It’s like there is a dead zone but only for the Osnap toolbar. The Grid Snap, Ortho, Planar, SmartTrack, etc selections, which are at the very bottom of the window work OK. Go figure???
I hope this is enough info for you to debug this with. At least I have a workaround.
Best Regards
Hello- If you have not, I’d unplug one of the external monitors and see if that changes how things behave on the remaining two. If that sorts it out, you’re probably overloading the gpu and need a beefier one to drive three monitors.
