Rhino7 freezes in debug mode
I have an ASUS VivoBook (11th Gen Intel(R) Core™ i7-1165G7 @ 2.80GHz, integrated graphic card). My Rhino7 freezes when I run debug mode (VS 2022.17.5.4). It works fine in release or debug “start without debugging” mode. Any suggestion on how to fix this?
Thanks
Ming
Run “SystemInfo” in Rhino and post thre results.
Rhino 7 SR28 2023-2-27 (Rhino 7, 7.28.23058.03001, Git hash:master @ 4ffc5d7156fbccf2a5d9fcc80e522b3851bc7f6c)
License type: Not For Resale, build 2023-02-27
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16Gb)
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 12-18-2020 (M-D-Y).
Primary OpenGL: Intel(R) Iris(R) Xe MAX Graphics (Intel) Memory: 1GB, Driver date: 12-18-2020 (M-D-Y). OpenGL Ver: 4.6.0 - Build 27.20.100.9040
> Integrated (slow!) graphics device with 0 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 27.20.100.9040
Driver Date: 12-18-2020
Driver Version: 27.20.100.9040
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\RhinoMAESTRO\Rhino\RhinoMAESTRO.rhp “RhinoMAESTRO” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.28.23058.3001
Hi @ming.ma.usa,
Keep in mind that when you are debugging your plug-in in Rhino, you are always running Rhino in “release” mode.
When debugging, does Rhino lock up when your plug-in is loaded?
When Rhino locks up, do you get any special errors in the Visual Studio output window or anywhere else?
Is the lock repeatable?
Anything you can provide might be helpful.
– Dale
Hi, Dale, I updated VS2022 to 17.5.5, and now Debug mode works fine. Thanks!
