Rhino7 crash when move curve editpoint using gumball
rhino7 for Macos 14.3 crash when move curve editpoint using gumball.
Please help.
{“app_name”:“Rhinoceros”,“timestamp”:“2026-09-18 22:06:53.00 +0900”,“app_version”:“7.38”,“slice_uuid”:“80bd4f71-905a-3eac-bb7e-14c398bbe0f7”,“build_version”:“7.38.24338.17002”,“platform”:1,“bundleID”:“com.mcneel.rhinoceros.7”,“share_with_app_devs”:1,“is_first_party”:0,“bug_type”:“309”,“os_version”:“macOS 14.3.1 (23D60)”,“roots_installed”:0,“name”:“Rhinoceros”,“incident_id”:“3519001C-2DDF-4B60-BC33-1D30903E01F8”}
“uptime” : 1100000,
“procRole” : “Foreground”,
“version” : 2,
“userID” : 501,
“deployVersion” : 210,
“modelCode” : “MacBookPro18,3”,
“coalitionID” : 92664,
“osVersion” : {
“train” : “macOS 14.3.1”,
“build” : “23D60”,
“releaseType” : “User”
“captureTime” : “2026-09-18 22:06:48.5613 +0900”,
“codeSigningMonitor” : 1,
“incident” : “3519001C-2DDF-4B60-BC33-1D30903E01F8”,
“pid” : 48623,
“translated” : true,
“cpuType” : “X86-64”,
“roots_installed” : 0,
“bug_type” : “309”,
“procLaunch” : “2026-09-18 21:13:33.0809 +0900”,
“procStartAbsTime” : 28021088002125,
“procExitAbsTime” : 28097726688385,
“procName” : “Rhinoceros”,
“procPath” : “/Applications/Rhino 7.app/Contents/MacOS/Rhinoceros”,
Hi mori -
Please run the Rhino SystemInfo command and copy-paste its output here.
Hi Wim,
Thanks for your reply.
Here it is.
Rhino 7 SR38 2024-12-3 (Rhino 7, 7.38.24338.17002, Git hash:master @ 97e36efa02d7f71638988290bb2d190fcf1b18c5)
License type: Commercial, build 2024-12-03
License details: Cloud Zoo
Apple macOS Version 14.3.1 (Build 23D60) (Physical RAM: 16Gb)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: MacBookPro18,3
Language: en
Apple M1 Pro (OpenGL ver:4.1 Metal - 88)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 10922 MB
Graphics: Apple M1 Pro
Displays: Unknown (255dpi 2x), Unknown (94dpi 1x)
Graphics processors
Apple M1 Pro
Color LCD (1512 x 982 @ 120.00Hz)
HP Z24n G2 (1920 x 1200 @ 75.00Hz)
USB devices
VLI Inc.: USB2.0 BILLBOARD
Apple, Inc.: EarPods
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Library/Chaos/Enscape/Enscape.Rhino.Plugin-net48/Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 4.18.1.1579
/Users/mori/Library/Application Support/McNeel/Rhinoceros/packages/7.0/Bullant/23.10.24.0/bullant.rhp “bullant” 23.10.24.0
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.38.24338.17002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.38.24338.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.38.24338.17002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.38.24338.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.38.24338.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.38.24338.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.38.24338.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.38.24338.17002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.38.24338.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.38.24338.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.38.24338.17002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.38.24338.1002
Hi mori -
When Rhino crashes, does the Rhino crash reporter pop up? I’m not finding any crash reports from your account in our system.
Does this crash also happen when you start a new file, draw one curve, and move one of the edit points? Does it also happen with control points? Or point objects?
Have you tried disabling those 3rd party plug-ins and then restarting Rhino?
When rhino crashed, the rhino crash reporter does pop up. But this is the first time I‘ve reported. Because it’s been crashing quite frequently lately. Other files have also crashed due to moving curve editpoint. Sorry I don’t remember it was control points or edit points. Now is edit points of a curve.
No I didn’t. Is it possible that moving control points of a Grasshopper referenced curve is causing Rhino to crash?
Hi mori -
Please start by disabling those and then restarting Rhino.
Anything is possible, but does that question mean that this crash only happens when you are modifying a curve that is referenced in Grasshopper?
Shut down Rhino. Start Rhino and start a new file from a factory-default template. Run Curve and create a single curve. Select it to turn on its points. Move one of the points with the Gumball. Does this procedure crash Rhino?
