Hi, i have a problem installing CounterSketch that tell me ‘‘Rhino64 bit is not installed’’, if i go to command prompt i see that i have Rhino6 64bit? where is the problem?
Does it need Rhino 7 and not Rhino 6? You might contact Stuller support directly for help…
i have both
Hello- if it is asking for 64 bit specifically, it is expecting Rhino 5, I would say - is there a newer version of CS?
OK, I guess CounterSketch is not finding the install then. I don’t know the program, so I don’t know how one can point it to your Rhino install. Again, perhaps Stuller support can help - or someone else who knows the program.
i thought being new CounterSketch i didn’t need rhino5. Why?
Aren’t Rhino 6 and 7 64bit?
Stuller website talks about Rhino 7 with “legacy access to Rhino 5”. Maybe you need 5 installed as well, and a legacy licence key.
Best clarify with Stuller.
CounterSketch is an old plug-in originally written by Gemvision, but still sold by Stuller.
The Rhino V5 installer adds both 32 and 64-bit builds of Rhino.
My guess is if you first make sure your Windows is fully up to date (Check for updates), and rebooted, running the V5 installer will add 64-bit Rhino 5 and fix the problem.
The final V5 installer can be found in the Archive section on the Download page.
