Hi, @piac
I use the component mesh from lines to create a mesh.
And the lines is exploded from the intersected polylines.
But the mesh has some holes.
I don’t know where is the problem.
Can you give me some help? Thank you!!!
Hard to say without a file. Duplicate lines maybe.
It can be many things.
- the polylines are not exploded
- ends don’t meet within document tolerance
- sheer luck. The algorithm does not guarantee to find all possibilities that the human eye might count as regions
- other bugs
You may also try Rhino’s _MeshFromLines
command.
Thanks very much!!!
I use Rhino’s _MeshFromLines
command and it works.
Maybe the problem is caused by the document tolerance.
By the way, does it effect the next operation if I change the tolerance in Rhino during the modeling process?
I mean whether only changing the tolerance before modeling make sense.
Thank you!
