I just noticed that when a file import plug-in has multiple file types declared, that when a file gets dropped onto Rhino the index in de ReadFile method is incorrect. When the file gets opened from the File>Open or File>Import menu, the problem does not appear.
When I drag a file with extension .dat onto Rhino when the file import plug-in (see below for code) is loaded, I get the following:
Observed output
Received index 0
TXT file
Expected output
Received index 1
DAT File
private int txtIndex, datIndex, wordIndex;
protected override Rhino.PlugIns.FileTypeList AddFileTypes(Rhino.FileIO.FileReadOptions options)
var result = new Rhino.PlugIns.FileTypeList();
txtIndex = result.AddFileType("Text file (*.txt)", "txt");
datIndex = result.AddFileType("Data File (*.dat, *.plt)", "dat", "plt");
wordIndex = result.AddFileType("Word Document (*.docx)", "docx");
RhinoApp.WriteLine("TXT index {0}", txtIndex);
RhinoApp.WriteLine("DAT index {0}", datIndex);
RhinoApp.WriteLine("WORD index {0}", wordIndex);
return result;
protected override bool ReadFile(string filename, int index, RhinoDoc doc, Rhino.FileIO.FileReadOptions options)
bool read_success = false;
RhinoApp.WriteLine("Received index {0}", index);
if (index == txtIndex)
RhinoApp.WriteLine("TXT file");
else if (index == datIndex)
RhinoApp.WriteLine("DAT file");
else if (index == wordIndex)
RhinoApp.WriteLine("WORD file");
return read_success;
@dale Currently I’m running SR16, and I see this happening again - I drag a file that can be opened by one of our file import plug-ins, the code gets the incorrect index in ReadFile(string filename, int index, RhinoDoc doc, FileReadOptions options) and file loading fails. Is this a known issue/regression?
I think the problem is related to the fact that we have multiple file import plug-ins and some of them have file types that have the same extension. When I create two file import plug-ins that support multiple file types, and a duplicate file extension on both of them having a different index, the incorrect index is given to the plug-in loading the file with the duplicate file extension.
Ideally, the system would track duplicate file extensions and present the user with a list of options while loading files, to choose if they want to load their file according to file type from plug-in A, or from plug-in B.
The files uploaded is a minimal reproduction case and fictional, but we do have multiple import plugins that have file types with the same extension for loading files. This is because we support a lot of file types; MARIN is a file oriented organisation where many simulation tools are developed, and extension clashes are unavoidable.
I have created a workaround in our plug-ins to handle this situation: when extension clashes are found, the user is explicitly asked to choose the correct file type on the commandline.
During testing I found that the error is not only happening when a file is dropped; it also happens when the file is opened from the menu and the required file type is not chosen from the drop down list, i.e. the file type is Supported files (*.*)
Furthermore, I found that dropping files with the extension .pat is completely impossible because Rhino thinks it is a hatch pattern file and gives a message that loading these will be supported in a future version, whereas in our case it is a PATRAN file.
Just to chime in and say our plugin would also fall into this category - for example see .nc and .anc below.
The file extensions are shared between different industry standard software.
I suspect I will have to do as @menno has done and add our own GUI to allow choice.
