Hi Enric,
I have just uninstalled V-Ray while all the other add-ons and plugins still installed. And HOLLA, I did not get the error window anymore!
VisualARQ works fine too
Reinstalled V-Ray, and it worked fine this time with no error window. Don’t know what happened!
Great!
The problem is that don’t know what was causing your GH errors.
When you reinstall V-Ray in Rhino 6, please, let me know if the issue appears again.
Is Rhino 6 still slow?
Regards,
Enric
Hi Enric,
No Rhino 6 is not slow anymore. It works fine.
V-Ray installed and worked fine too.
But I noticed something it could be the issue I do not know.
When the error window used to appear, I noticed that Grasshopper load at the beginning at the same time as Rhino 6 window load. which was strange and I don’t why I didn’t mention this before (Maybe I thought it’s okay).
However now after the error window stopped, grasshopper only load when Rhino window completely open and I press one of the VisualARQ tools.
And I guess this what makes run slow then at the beginning.
Probably,
Anyway All the Best Enric
Overall, I am enjoying the new ViaualARQ however, I have a similar experience with VisualARQ crashing Rhino 6. I do not have, nor have had V-Ray installed. I do have Brazil and Bongo plugins as well as several grasshopper plugins. When starting Rhino, a list of grasshopper errors will appear (see attached txt file), several of which name the Clipper Components plugin as having some issue. The Clipper Components plugin will not properly load despite several uninstall/reinstall attempts.
GH_Load_Ex.txt (3.7 KB)
Running Rhino 6 with VisualARQ does feel slightly more sluggish than running Rhino without the plugin. Rhino also appears slower in updating the graphics of ViaualARQ components and misses some objects while in shaded mode. Technical mode appears to work fine.
I’ve found and fixed the bug!
Here is an explanation about the bug:
And here is the installer for the latest WIP build of VisualARQ 2.1.1:
https://visualarq.s3.amazonaws.com/download/visualarq-2.1.1.12217-rhino6-setup-snapshot.msi
Please, test it and let me know if you still see errors when loading VisualARQ or Grasshopper. My plan is to publish it later today if there are no issues.
Thanks again for your patience and your help!
Enric
Hi! I dont know, if this is relevant comment here, but I have just noticed a display error in rendered (and others) display views using skylight and shadows. There are some shadow fragments when using clipping plane. This happens only with VisualARQ loaded to Rhino 6. See picture bellow.
Hi Enric,
I have downloaded and tried the WIP version, and it works pretty fine. No errors appeared when loading VisualARQ nor Grasshopper. And it appears to be slightly faster in Rhino 6 than the 21.0 version.
As @petumatr mentioned above, I don’t have the shadow fragments when using clipping plane, but I do noticed that VisualARQ objects appears to have some issues when using clipping plane in some display modes:
-Raytraced display mode: Clipping Plane ignores all VisualARQ objects.
Arcitic Display mode: Clipping plane does cutting through the VA Objects, but it ignores some.
Rendered & Hidden Display modes: Clipping plane does cutting VA Objects but it appears to be like a mirror I don’t know.
The other display mode are just working fine displaying the cutting objects.
Just a quick note on Raytraced, that display mode doesn’t support clipping planes as of yet.
VisualARQ 2.1.1 has just been released:
These display issues on rendered display modes when a Rhino clipping plane is enabled are fixed. Raytraces display mode still has some problem with VisualARQ. We’ll try to fix them for the next update.
Let me know if any of you have problems with this new release.
Regards,
Enric
Hi Enric,
These screen shots above are generated within the VisualARQ 2.1.1
I think you’re using a pre-release 2.1.1, as I’ve fixed this bug 3 hous ago and I haven’t publish any version after that…
Can you please download the final 2.1.1 and try again?
Thanks,
Enric
I used this one.
I will download the one you posted recently.
Some issues I’ve already experienced:
- Rhino crashes every time I try to extend walls causing a connection / splitting walls at T-shaped connection.
- Spaces in hidden view are unselectable
- If I save file in Rhino 6 with VA objects to Rhino 5 format I cannon open It in RH 5
- VA object’s properties panel has 2 parallel scrollbars when they do not fit in available space on screen and they seem not to work correctly
Hi @Tomek_Wloga,
I’ve tried to exend a wall until it reach another wall resulting in a T connection without a crash. Can you send me a sample model and the steps to reproduce the crash?
I tried also to create 4 walls and a space in a hidden viewport, and I can select the space without problems. Can you send me also a model where your’re seeing this issue?
Again, I tried to save the model with the 4 walls and the space in Rhino 6 using a Rhino 5 format, and I have been able to open it in Rhino 5 with VisualARQ 2.1. Are you using VisualARQ 2.1 in Rhino 5? VisualARQ 2.0 cannot open files from VisualARQ 2.1.
I’m unable to reproduce this issue. Can you send me an screenshot?
Thanks,
Enric
I also experience the Rhino 6 crashing every time I print to PDF with vectors.
Hi @Tomek_Wloga,
Which PDF printer are you using? We’ve been using here the “Microsoft to PDF” and “CutePDF” without problems. Using the “Rhino PDF” we’ve just discovered that some objects are not visible (specially texts) and we’re currently investigating why.
Is the crash happening all the times? Or only when trying to print some specific models?
Thanks,
Enric
When I use Bullzip PDF printer it works ok, but it crashes when using Rhino PDF.
I’ll send you the model via e-mail.
Enric −
The v2.1.1 update to VA appears to have fixed several of the earlier crashes I was experiencing, thank you! Now I have a new bug to report which is a more consistent crash. A specific model (or any VA file with the slightest complexity) causes Rhino to crash either when opening or within moments of opening. The file can be opened and worked on when VA is not enabled; all views are set to wireframe; and tried deleting the last few VA objects added to the file but a crash is inevitable.
I have sent a plethora of crash reports to McNeel (under my user name) over the past two days that are related to this crash.
Cheers
