so I’m using rhino3dm for python (3.7) on a windows-machine. I loaded a 3dmFile via python and now want to read some object attributes, basic stuff.
import rhino3dm
import tkinter
import os
#rhino3dm is a c-library
#for maximum speed, stay in library-objects as much as possible
wdir = os.path.dirname(os.path.realpath(__file__))
#string needs to be replaced with userinput
file = wdir + '/model.3dm'
print('loading model...')
model = rhino3dm.File3dm.Read(file)
print('model has been loaded')
objects = model.Objects
for i in objects:
print(i.Attributes.Name) #works
print(i.Attributes.Type) #Nope
print(i.Attributes.GetType) #Nope RhinoCommonSyntax
print(i.Attributes.GetType()) #Nope RhinoCommonSyntax considered Method-Syntax
print(i.Geometry)
print('-----------------')
So what are the attributes that I can read? Is there a way to show all of the attributes given to the object-class? I tried:
It’s a bit off-Topic, but do you know if rhino3dm supports fbx-imports? It works in rhino so I’m curious if there’s a way to put that functionality in rhino3dm.
Hi @nathanletwory,
I find it difficult to understand where to start from with RhinoInside. Is there some step-by-step tutorial not involving commercial software like autocad? From some of the threads it looks like RhinoInside is similar to DLL injection into a running process
