Rhino won't start
What should I do from here? It’s stuck like that:
When I force-quit I get a report. Here’s the first few lines (I can send the whole report if needed):
Translated Report (Full Report Below)
Process:               Rhinoceros [72142]
Path:                  /Applications/Rhino 8.app/Contents/MacOS/Rhinoceros
Identifier:            com.mcneel.rhinoceros.8
Version:               8.14 (8.14.24345.15002)
Code Type:             ARM-64 (Native)
Parent Process:        launchd [1]
User ID:               501
Date/Time:             2025-01-09 11:56:13.5744 -0500
OS Version:            macOS 15.1.1 (24B91)
Report Version:        12
Anonymous UUID:        3F34F02A-A723-CA8D-6BC4-84FEAA297DC9
Time Awake Since Boot: 750000 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_CRASH (SIGABRT)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Termination Reason:    Namespace SIGNAL, Code 6 Abort trap: 6
Terminating Process:   Rhinoceros [72142]
Application Specific Information:
abort() called
Restart your Mac.
Any luck?
Do you or did you have enscape installed on this machine? If so see Option 2 in this guide (enscape for a short time was creating folders with improper permissions)
https://wiki.mcneel.com/rhino/mac/home/rhinomacwontstart
No Enscape.
I think the only plug-in installed is Bella 24.6.0.0
Is there a way to start in “safe mode”?
Unfortunately there isn’t a Safe Mode for Rhino Mac.
To disable a plugin you can follow this guide.
https://wiki.mcneel.com/rhino/mac/delete_plugin_mac
Any firewalls or anti-virus blocking? you should be able to reach this site in your browser. https://api.mcneel.com/
Okay… today it started normally, without me doing anything. :man_shrugging:
