I was only looking for a temporary fix since you mentioned that you have an urgent project and that you were up all night trying to get this to work. I donāt have any other solution at the moment; sorry.
If the redistributable package fails to install, please contact Microsoft for help, and also please let us know what they did to solve the problem. After that, you should be able to install Rhino 64-bit successfully.
If you continue to get installation errors, please send the full install log (available in the last screen of the installer) to me by private message, and Iāll investigate further.
@brian Firstly, I attempted to install the package you linked me to above.
Following that, it failed and gave me a new error, the error was āError 1935, error during installation of assemblyā¦ā etc.
So what I did was googled the error, which came to a fix on a microsoft page, that gave a few methods of fixing this error.
Hereās the link to that page: http://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/error-1935-error-during-installation-of-assembly/6eb81d6c-ae2a-483b-9db0-c228fb5828e4
(Step 1 was what worked for me)
I tried the first step, which utilised command prompt, then restarted my computer.
I then tried to install that package again, and it worked this time.
After that I went to install rhino x64 bit again and this time the installation worked.
So now everything is all up and running.
Thank you so much for the help @brian , without your help I would not have been able to fix it.
