Rhino WIP won't update or uninstall
Rhino WIP cannot be updated or uninstalled on my windows 11 machine. It returns the attached error, and the troubleshooting programs suggested in previous threads are no longer supported by windows. I tried a manual uninstall using BC Uninstaller and then installing clean once again, but it returned the same error.
Hi Owen -
If that refers to Microsoft’s Fix It tool (link), in our experience, that continues to help users, also on Windows 11. I just downloaded it and ran it on Windows 11, and that seems to work just fine.
On the “Windows 11” tab on Microsoft’s page, they claim that the new built-in “Windows Troubleshooters” should detect and solve issues with failing uninstalls. Did you try those?
Apart from that, did you try manually uninstalling using the steps outlined here? → Manually Uninstalling Rhino [McNeel Wiki]
We see lots of cases where use of tools such as CC Cleaner do a lot of damage. I hadn’t heard of " Bulk Crap Uninstaller" before, but I’d personally try resetting the PC before going there.
I have the same issue running “uninstall” from Windows 11s app center. Also, I cannot install newer versions from Rhino WIP as the old one cannot be uninstalled. I did not run CCleaner of anything as far as I remember. Log is attached. I will try to remove it manually follwoing your links :slight_smile:
Rhino_WIP_20260829193558.log (22.7 KB)
I have removed after 3ds max installation showed me failure many times however I have never had issue installing Rhino but 3ds max. So I tried what Autodesk suggests but never worked for me.
Here how did I succeed to unistall and installation:
Uninstall Rhino and its all plugins, renderer plugins too via Programs and features (Windows)
Delete every location of their left in C: disk, for instance
%localappdata%
%appdata%
%temp%
Etc.
Then this is a must, restart Windows,
Find every Rhino releated registry entry, delete them.
Restart Windows again then install Rhino but let the Rhino install required files in installation settings.
Hope that fix your problem.
