how works Trim now?
Before i can select trimed object by cross window, now i can’t. Just single object click by clic…
How works “Fence”?
how works Trim now?
How works “Fence”?
Seems to be working here in a couple of quick tests… Can you post a simple example that you can repeat that isn’t working?
Hi @Helvetosaur ,
Ok, I tried it again, and it seems the issue is caused by one specific clipping plane—see the attached file. If I delete the plane or turn it off in the ‘Top’ view, Trim works fine…
trim_test.3dm (3.3 MB)
@Chita if ApparentIntersections=no and the line isn’t physically intersecting, that’s the expected behavior.
@Gijs But the line are physically intersecting and only trim with window selection not working.
Problem persist if is ApparentIntersections=YES too
@Gijs - I am seeing the same sort of thing, it does seem to be related to the clipping plane, if you delete that, it works as expected.
sorry, missed the later reply,
now logged as: RH-97096 Clippingplane prevents Trim to work correctly
