Hi @tay.othman
space mouse [enterprise, but that shouldn’t make a difference] is working here as normal after updating to 8.0.22340.12306, [Mac OS11.7.1]
Akash
Hi @tay.othman
Akash
I have a feeling it is a windows only issue, I find it related to this.
Continuing the discussion from Rhino 8 WIP Available Now!:
@BrianJ can you take a look?
Hi @tay.othman,
Cannot reproduce this on Windows 11 Pro 22H2 with Rhino 8.0.22340.12305, 2022-12-06.
These are the settings I’m using:
Regards
Jeremy
Thank you for Reporting, I have 22H2, Yesterday’s WIP, with Identical Settings to yours.
Can you try to Turntable a box for 20 seconds, I get the issue in 12/06 WIP but It works okay on Rhino 7.
Turntable works as expected: I tried different speeds in both directions, in wireframe and shaded modes.
Here’s my systeminfo if you want to dig deeper for differences:
Rhino 8 SR0 2022-12-6 (Rhino WIP, 8.0.22340.12305, Git hash:master @ d4a00cc453abcfe9fc7a8e109856bf957cdda0d3)
License type: Commercial, build 2022-12-06
License details: Cloud Zoo
Expires on: 2023-01-20
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display: NVIDIA GeForce RTX 2080 (NVidia) Memory: 8GB, Driver date: 10-12-2022 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3090 (NVidia) Memory: 24GB, Driver date: 10-12-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 522.30
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-12-2022
Driver Version: 31.0.15.2230
Z-Buffer depth: 24 bits
Total Video Memory: 24 GB
C:\Program Files\Next Limit\Maxwell for Rhino\maxwell_rhino_8.rhp “Maxwell for Rhino” 5.2.6.3
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
C:\Program Files\Rhino 8 WIP\Plug-ins\Commands.rhp “Commands” 8.0.22340.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.22340.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.22340.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino 8 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 8 WIP\Plug-ins\Constraints.rhp “Constraints”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.22340.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoRoslyn.rhp “RhinoRoslyn” 8.0.22340.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.22340.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCPython.rhp “RhinoCPython” 8.0.22340.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.22340.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 8 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 8 WIP\Plug-ins\ConstraintsUI.rhp “Constraints UI” 8.0.22340.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\SectionTools.rhp “SectionTools”
can you share your spacemouse settings inside rhino? this is mine, set to object mode with locked horizon.
Thank you so much, This confirms that We have identical settings, likely some system variable on my side causing this, I’m going to test it on another machine with fresh installation and will let you know,
I’m running the same driver as @tay.othman but do not see the issue on my workstation. I think I’ve seen it on my laptop but I’m not sure.
Rhino 8 SR0 2022-11-29 (Rhino WIP, 8.0.22333.12305, Git hash:master @ 9fb4f4f01afc8d6328a29f9741f21a77a4b85d1e)
License type: Kommerziell, build 2022-11-29
Expires on: 2023-01-13
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 1.3e+02Gb)
Primary display and OpenGL: NVIDIA RTX A5000 (NVidia) Memory: 22GB, Driver date: 11-23-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 527.27
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
NVIDIA Quadro K2200 (NVidia) Memory: 4GB, Driver date: 11-23-2022 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 11-23-2022
Driver Version: 31.0.15.2727
Total Video Memory: 23028 MB
C:\Users\martinsiegrist\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\KeyShot9RhinoPlugin (ecfe8d1f-876a-460f-aa5e-3dd816936811)\1.4.0.0\KeyShot9RhinoPlugin\Rhino 7\KeyShot9RhinoPlugin.rhp “KeyShot9RhinoPlugin” 1.4.0.0
C:\Program Files\Rhino 8 WIP\Plug-ins\Commands.rhp “Commands” 8.0.22333.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.22333.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.22333.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.22333.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoRoslyn.rhp “RhinoRoslyn” 8.0.22333.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.22333.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCPython.rhp “RhinoCPython” 8.0.22333.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.22333.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\ConstraintsUI.rhp “Constraints UI” 8.0.22333.12305
I tried too. Latest WIP (just installed).
The rotation with 3dmouse have those usual little “hiccups” …
Edit: I see it too.
Here the steps to replicate it on my machine:
I’m having a flashback… I remember Steve Baer did something about this for V7.
I’ll try this later on my other machine. Currently I’m on a very old one:
System info:
License type: Commerciale, build 2022-12-06
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 16Gb)
Primary display and OpenGL: NVIDIA GeForce GTX 770 (NVidia) Memory: 2GB, Driver date: 7-11-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 473.81
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 7-11-2022
Driver Version: 30.0.14.7381
Total Video Memory: 2 GB
C:\Program Files\SimLab\Plugins\SimLab PDF From Rhino\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Rhino 8 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8 WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
I think I was able to resolve the issue, The Jumping phenomenon has been eliminated by disabling V-Sync inside Nvidia control panel, not sure how it is applicable but it is working fine for now.
Thank you Guys
@brian I am not able to replicate the issue here with an old Space Navigator puck and the latest v8 WIP. Sounds like at least for @tay.othman the issue was an Nvidia setting.
thank you @tay.othman, I had the exact same issue on my Windows machine… very annoying. Thanks for posting your solution (please mark your answer as a solution, so others with the same issue can find it quickly)
Thanks, Rudi
Thank you for confirming that this issue is not exclusive to my machine, I guess once more people can test V8 we can probably isolate the root cause of the issue.
Sure thing, with these kinds of bugs team work is important ![]()
Super hard to find the root cause otherwise…
