What I am struggling with is that there seems to be no clear way to control hatch color and hatch lineweight independently from boundary color and boundary lineweight through the layer settings. For me, it becomes a real mess when trying to control each element as in the references below. Some of this seems to be handled through section styles, but section styles also partially override the usual print color / lineweight logic, and vice versa. At the same time, I cannot find a clear setting that defines the lineweight of the hatch pattern itself. Somehow it is connected to the layer print width. The lineweights or hatch and boundary weights also do not seem to match properly, even when the same weight is assigned. In some cases, a 0.50 appears much thinner than a 0.13. The background also does not seem to show up in the layout. See the reference above.
Another issue is the line hierarchy. In section drawings, load-bearing elements should read heavier than non-structural or visible elements, but at the moment the order and weight of the lines often appear in the wrong arrangement and do not seem to be adjustable. Also the boundary comes before the hatch, which is often not the case especially when using colors/greys/non-blacks. Or is there a way to control this that I am missing?
The most important point for me is the printing setup for layout export. I need reliable control over how boundaries and hatches are printed in the final drawing output, not just how they appear in the viewport.
There should be a setting somewhere that allows a clear print override for these elements or just a solution that let’s you somehow force settings.
Also, scaling is hard to understand. But that is another issue.
The kind of output I am aiming for is:
Note that we need control over boundary color, boundary lineweight, boundary linetype, background color, hatch linetype, hatch lineweight, and hatch color, either per elements or per layer, including control over their arrangement and hierarchy.
I cannot stress this enough: all of this is part of the grammar of drawing. If something has the wrong lineweight or color, it can also cause problems during construction. This is not just a feature; it is essential. Otherwise, it is not really usable.
Edit: I am also getting confused by the terminology itself: print width, lineweight, etc.
