Rhino WIP Feature: Patch re-implemented
ic, so if that is normal geometry i guess it should just work there either. i am sure @menno will figure it out, he is on it, i am really stoked that general shapes besides elipses work now without having to break a leg. though there are still slight advantages in the general shape when you use the old patch but i might get to that at a later time.
also it would be really good if the command could close with space.. pls pls pls.
Sometimes changing the degree of the surface makes a big difference, despite that the geometry is 100% identical as a shape. ā€œBlend surfaceā€ is very sensitive in this regard.
I’m experiencing a slowdown not only during the command selection phase, but also after the command has been executed. I encounter a temporary freeze where I’m unable to orbit around the object for a short time before navigation resumes.
@brvdln does that happen always, or after some time? Does it happen again if you close and reopen Rhino?
If I restart Rhino, the problem does not occur.
I’m not sure, but this slowdown seems to occur more often when the document has a lot of layers, especially sub layers.
In that case, after selecting a constraint, it takes ~1 sec. to show the label.
Thanks for that, I have made a ticket here RH-94426.
A post was split to a new topic: Patch: UV indicator
RH-94426 is fixed in Rhino WIP
This is really solved, no delays anymore in here.
@brvdln still curious about the delay on adding the result to the document. Please let me know if that keeps happening.
@menno Now everything is okay, I’m not experiencing any slowdowns. :+1:
