Rhino WIP Feature: Markup
Are you talking about CopyToClipboard command or the button that copies the image to clipboard?
The latter only copies the current state of the markup, not what’s saved.
It’s not random, it’s <3dm file name>_<markup name>.jpg , Keep in mind you can multi select few markups and export them at the same time with this naming convention. It’ll be inconvenient to pop up a dialog asking for a name for each one.
Logged here: RH-94620 Print all markups to PDF
It worked weirdly in the earlier version of WIP. In this the functionality works great.
I presume that the forward/backward leafing functionality at the right top is supposed to restore the view used in the Markup? This does not seem to work always. (But maybe those Markups are from an earlier version, so that’s why the view is not restored.)
Now the million dollar question: Does it also restore active clipping planes? And does it restore the Layer state ? If not, then you need to add that …
And does it restore the active Cplane for the Markup? And the “Project to Cplane” snap ?
And could you briefly explain were the Markup is stored? Because it seems to land in Layers used in the files. Meaning that if those Layers are off, then there will be no Markup visible ? Or is this a misunderstanding of the functionality?
Logged here:
RH-94866 Cannot move dimension grips during markup
Logged here: RH-94867 Stretch during markup
RH-94866 is fixed in Rhino WIP
RH-94863 is fixed in Rhino WIP
RH-94867 is fixed in Rhino WIP
RH-94782 is fixed in Rhino WIP
What I mean is that in other views, the operation axis can be seen. Use the operation axis and perform a series of command operations (such as stretching, proportional scaling, etc.) It is not a curve or a line
During a markup, operations in other viewports aren’t permitted.
Switch Rhino to English language.
Create a Markup and save the file.
Switch to German.
Load the file.
Double-click the Markup in the Markups panel.
The Markup UI doesn’t come up.
Instead _Move is started.
Thank you, logged here and will fix ASAP:
RH-95154 Markup in German
Hi
The copy button opens a panel—why isn’t it a direct copy-to-clipboard action?
like Ctrl+C, copying the viewport directly to the clipboard without any UI popups.
That is not the function of that button. It copies a screenshot of the viewport into the clipboard.
It’s running _ViewCaptureToClipboard
RH-95156 is fixed in Rhino WIP
(9.0.26132.12305, 2026-05-12)
Save the model file while a markup is active.
Quit + restart Rhino.
Load the model file.
The viewport is locked.
Double-click in the markup panel doesn’t do anything.
Unlock the viewport.
Try again in the markup panel.
Markup seems to conflict with the viewport lock.
This one is working now.
Hi Charles -
If you at this point in your video…
… click the Cancel button in the lower right corner of the viewport, the markup is closed and the viewport unlocked.
I’ll get it on list for a tune-up.
RH-95492 Markup: Document Opens with Locked Viewport
That’s a workaround for now.
The system should be foolproof.
Good it’s on tune-up list.
When a viewport is intentionally locked, then it gets unlocked.
That can’t be wanted.
The viewport lock for Markup must not interfere with the normal viewport lock.
