@CADARTZ just posted a screen-shot of Solidworks in another topic, which reminded me that some people praised it for having a “futuristic UI” due to the limited amount of icons. Meanwhile, they wrote some negative words about Rhino’s overly-crowded toolbars with much more icons that “confuse the new users”. Well, as you can see, the “futuristic UI” has super large top toolbar buttons consisting difficult to read small icons that consume a lot of space just for one tool at a time (literally double the height of the Rhino icons that support both, LMB and RMB function), whereas the additional icons are accessible via holding these to open a sub-toolbar. Solidworks and other CAD programs are praised for having bad optimization of the toolbar space with huge top icons and sub-toolbars, while Rhino is criticized for optimizing the space with easy to read icons that not only have sub-toolbars, but also can consist two command into a single icon. This is a clear example of double standards and biased opinions.
Also, keep in mind that Rhino has a huge amount of icons, because it’s the “Swiss knife of CAD programs” and supports all main geometry types (NURBS, SubD, 3d meshes, point clouds), as well as: drafting, texture mapping, materials, lighting, rendering, analysis, UDT, transformations, CPlanes, the best viewport manipulation and 3d mouse support in the industry, robust layer system, a broad file export options, highly customizable display modes, selection filter, Grasshopper and so on. Plus, the new Rhino iterations also support auto-hide side panels at either side, which is a further optimization of the screen space that most other CAD programs lack.
I have 64 icons on the Standard toolbar (customized) that consist additional 59 commands due to the RMB functionality, plus 3 more icons that are hidden on the right side behind a double arrow for quick access due to the lack of space. That makes a total of 126 commands for a convenient single-click access in just one toolbar. For comparison, Solidworks has just 17 commands in the standard toolbar that take a bit more space that Rhino, which itself (in my customized Rhino 7) has 123+3 commands, along with 15 extra tabs consisting hundreds of extra icons (not counting the sub-toolbars). Solidworks also has several icons on the status bar (Save, Open file, Home, Print, Select, Options etc).
The only thing that I like in Solidworks’ UI is the Save, Open and some other icons being placed on the title bar on the top, so they are always visible. Rhino has these main icons placed in the “Standard” toolbar only, so switching to any other tab will hide them. That alone stops many Rhino users from taking advantage of the top toolbar tabs.
The “Menu” bar also could be optimized by making it (optionally) accessible via some arrow icon on the title bar. That approach is commonly used in most web browsers.
