Hi all,
In the Rhino WIP we’ve focused on fine-tuning the Gumball to improve usability in everyday modeling scenarios.
Orientation and Location
SubD Modeling is an iterative process or adjusting faces, edges and vertices over and over until finding the right shape.
In Rhino 8 and previous versions, you would need to:
- Select your Sub-Objects
- Relocate and orient the Gumball
- Make your transforms
- Repeat…
In Rhino WIP, the Gumball remembers its location and orientation for selection sets. This is key in streamlining the formfinding process.
For Groups
We’ve made the Gumball remember its orientation and location for groups. This means that when you reselect a group the Gumball will return to the same orientation and location it had the last time the group was selected.
For Sub-Objects
Similarly, we’ve made the Gumball remember its orientation and location for SubD Sub-Object selections. This means when a same selection of Sub-Objects is selected again later, like with a named selection, the Gumball will remember its previous orientation.
Also, any previous sub-object selections, that become part of subsequent sub-object selection set, are able to remember their own “frame” when reselected.
Snappy / Smooth Toggle
When the Gumball is in Snappy mode, we’ve begun drawing the Gumball menu ball as a square. If it’s in Smooth mode, it keeps the traditional circle. This gives a visual indicator of how the Gumball will behave when a drag begins. We’ve also added a Command Line option to toggle the style (S).
New Rotate-Extend Mode
We’ve also enhanced the extend mode on the Gumball by supporting rotations. In Rhino 8, you could only use the Move tool to extend a face. Adjacent faces would follow along. However, when rotaing a face, adjacent faces would deform.
In Rhino WIP, when CTRL+Shift is held with the rotate handle on a face the adjacent faces are rebuilt to follow the changes.
We’re hoping these new features make the Gumball feel a bit smarter and ease some of the common pain points.
Looking forward to your feedback!
