Rhino WIP now includes a Drafting Symbols library of blocks.
What are Drafting Symbols?
Drafting Symbols are commonly used 2D blocks that can be used to create drawings. They are standard 2D representations of common 3D objects (eg: doors, windows, piping, etc). They also include Title Blocks, Arrowheads, Detail Titles, etc.
Note: Currently Drafting Symbols are available on the Windows WIP only. Mac WIP implementation is being worked on and we will let you know here when it is ready.
These 2D symbols can give you a quick start on creating drafted drawings. Previously in Rhino, you would need to manually draw these symbols and create your own library for use with other files and for sharing with your team. Symbols can also include additional user-defined data and text fields to customize for each detail and drawing.
Folders represent categories of symbols and like materials the thumbnails show the current folder content and all the sub-folders. Adding content in the lowest most folders will make category and sub-category browsing easier.
Steps to Use:
Open the Library panel by right-clicking on the grey area of the sidebar (to the right of the UI):
My normal workflow is to do drafting in autocad lt and as such have an extensive block library already built and want to know if I’ll need to rebuild it to shift across.
Sure it should work for that too. Although, I have found it better to convert to 3dm because there are some differences with Blocks and attributes if that is being used.
Yeah, I expected it’d work better to eventually have rhino specific symbols, but obviously a lot are only used occasionally, so good to know I can just import them as needed.
I see that I can add my own block files (and set up my own folders to keep them apart) but while I can see the block name there doesn’t appear to be a way to set up icons yet like the McNeel blocks have. Nor any alternative to navigating the Appdata tree to save the block definition, which may not be allowed in a corporate environment.
