Rhino WIP Feature: Clipping Drawings Section Through Curves
In the Rhino WIP, curves are supported when creating clipping drawings. If the curves are in the background, then those curves will be projected to the clipping drawings.
Video of Clipping Drawings Section Through Curves
What are Clipping Drawings?
Clipping drawings are dynamic 2D drawings extracted from clipping sections and are projected on either the clipping section plane or placed parallel to World XY-Plane.
Why include curves?
For models that include curves as background objects, or the clipping-plane cut through them, it is expected that these curves show in the background of the drawings, but also output intersection points as part of the section.
How to include curves in the clipping drawings:
  1. Run the ClippingDrawings command.
  2. In the ClippingDrawings options, set the AddBackground=Yes
  3. Follow the prompts to create the drawing.
If the clipping plane intersects with curves, “Point” layer is added with all intersection points.
If there are background curves, they are now included in the visible and hidden layers.
Section Layers
Try it now…
The rest of SectionTools Enhancements can be found here…
This is an excelent addition. It was really needed. Thank you!
