Rhino WIP Clipping Section Drawings - Draw hatches but not outlines
Thank you for all the new drafting functionality in WIP, it has been a big help! I do have one remaining issue though.
Is there a way to just draft the hatch from clipping planes and not the outlines of the shape?
When using Rhino to model buildings it can be helpful to have components such as wall be separate rectangular volumes rather than a monolithic closed polysrfs for iterations and client driven updates (see Image 1&2). I have modeled a basic wall intersection with structure/insulation(Black) on the inside and wall finishes on the outside(red) However, I would want at least the interior to be drafted as if they were one monolithic volume (see images 3).
I think the easiest way to achieve this would be for a toggle to print just a hatch and no border. Does this already exist? If it doesn’t, that functionality would be greatly appreciated.
Thanks,
Neal
Hi Neal,
Trying to think of way to handle various conditions that could arise without adding complexity.
For instance, when two walls of different types are at the T, or gyp conditions where you want the end to show.
Hi @Japhy , @rajaa .
I would propose having an option for ClippingDrawing creation, something like “Make outline = Individual/Compound”.
And in “Compound“ case for touching contours make them as curve boolean union.
Hi Neal -
The short answer would be “yes”.
Unless you use the “Source layers” option, a layer for the section curves and a layer for the hatch boundaries is created. You can turn these off in the layers panel.
That will turn those off for all objects, though. In your specific example of a solid hatch for the outer wall elements and a patterned hatch for the internals, that would work. (though you wouldn’t get the lines at the three ends of the T structure in your image).
I have put the request on the list as RH-92619 ClippingDrawings: Merge Common Sections
The ability to merge common sections would be great solution because it would allow one to still use the “source layers” option and produce an interstitial line in the case highlighted by Japhy.
Thank you for your help
RH-92619 – Merge Common Sections: possible workflow idea
With Rhino 9, I see a big step toward using Rhino not only for modelling, but also for producing documentation. Clipping Drawings, Section Styles and the developing AI workflows make Rhino feel much closer to becoming a single environment for both design and documentation.
Merge Common Sections would not solve everything, but I think it could noticeably improve drawing quality.
In complex models, especially in architecture and construction, larger assemblies are usually built from separate elements. A reinforced-concrete structure may visually behave as one monolithic system, while the model still needs separate walls, beams, columns and slabs. Using destructive SolidUnion operations only to clean up section drawings would remove useful structure and editability from the model.
I am not a programmer, so this is only a conceptual idea, but I tried to keep it close to the existing Rhino 8/9 section workflow.
The idea is to keep the current per-object section result: separate hatches, section curves, source relationships, layers and attributes.
The additional step would only classify shared boundary segments.
If two adjacent section regions use the same effective Section Style, their shared edge could become a Common Section Boundary. The Clipping Drawing could then either display it normally, suppress it, or optionally output it to a separate category/layer.
A per-object Preserve Common Boundary override would also be useful, because sometimes two elements have the same Section Style but the joint should still remain visible. This avoids creating artificial styles like Concrete_1 and Concrete_2 only to preserve one line.
So the main idea is simple:
Source Breps stay separate.
Hatches can stay separate.
Existing attributes and relationships remain.
Only the graphical treatment of the shared boundary changes.
Possible future extensions
It could also be useful if generated section edges retained source-face metadata/index information. This could later allow per-face material overrides to affect section linetype or other edge properties.
A more distant extension could be Common Faces, where coincident faces are recognised when the topology can be resolved reliably, with fallback to current behaviour when it cannot.
Thank you for the feedback and for drawing a diagram for your ideas.
I would love to learn better understand what issues your proposal solves. Can you share examples of what is produced using current tools, and what is the desired or missing part that you think should be supported?
Hi @rajaa ,
Sorry for intruding into the talk. Could you please push up the idea of separate outline creation for each geometry piece instead of just one combined?
Are you asking for a per-object silhouette in ClippingDrawings?
Yes, that’s correct.
@Screamer would you be interested to have both the “overall” silhouette and the “per-object”, or usually one or the other?
@rajaa I think if we would have per-object, it covers the overall as well. Overall is not needed then to me, unless I don’t see the possible other’s case.
Request filed here…
Thank you for making a YT. I’m seeing it as V10 target. Is it not feasible for V9?
New features in V9 are locked at this point.
To me, this is a fix, not a new feature.
And the bug was reported back in August. Unfortunately, nobody paid attention to it during that time.
