I Saved a rhc from 8. Tried to load it in 9, and nothing happens…
I can however create a new container in WIP, save and open…
I will rebuild, but i expect others will need it…
@alasdair_mcphail can you give me the RHC so I can test this? I’d like this fixed so you don’t have to rebuild! ![]()
I just came back to this. I thought i uploaded something some time ago, but perhaps it didnt work.
I still see the same issue.
To Confirm again,
any RHC I create in 8 does not do anything when attempting to load to WIP, (using the container manager)
RHC created in WIP will open ok in WIP
Thanks
For anyone wanting to continue their workflow from 8 , a workaround is:
_OptionsMigrate
selecting option 2 - earlier version.
which will bring everything across.
Will monitor this for now, as i dont know what gets broken in the process. I will be saving the important menu bars out from RH9 WIP in case i need to completely reset .
Sorry I didn’t reply @alasdair_mcphail,
I’m still working on these .rhc files, but they are an absolute mess and I don’t think they should exist. If OptionsMigrate works for you, I’d suggest using that going forwards ![]()
No worries at all - Now that i have a workaround I am good - hopefully it works for others too.
Good luck with it!
