which is plugin for Rhino viewport widgets?
In this picture (Peek ViewPort)
The result of this plugin is active ViewPort in background of Grasshopper Convas similar dynamo in Revit but we Can’t select Object in viewport ; So i suggest that add bottom To user enable Or disable Selectable Viewport)
Or we glad if anyone suggest c# code for this purpose !
In this topic some example but very cool if add enable or disable bottom to select able object in viewport :
