Rhino viewer for win7 laptop options
page doesnt seem to exist by browsing to it,
so I shall post the question here.
What is there that a friend with a win7 old laptop can use to view a Rhino V5 file with,
featuring an obj ?
Enough to rotate and take measurements from it ?
I dont imagine his laptop has an Nvidia etc, or much extra muscle, just a bog standard laptop.
Else could he use an online viewer, that would then use the GPU and power of a server, is that how an online alternative works, or does he still need the necessary graphics and power on his laptop, does the online method provide the graphics and power ?
Cheers
Steve
Hi, @Steve1. At this point in Rhino’s software development cycle, it’s a pretty tall ask to get Rhino 5 working on Windows 7, since both Microsoft and McNeel don’t support Windows 7. Our Rhino 5 system requirements are here: Rhino - System Requirements for Rhino 5. You mentioned an online viewer that can handle basic rotation and measurements. One of the viewers mentioned in the post you replied with is still functional here: byRhinoView. FYI, all evaluation versions of Rhino (v9 thru v6) turn into viewers that will allow opening .3DM files, rotation, and basic measurements. Even if someone starts a new v9 eval, they can download and install v6 and hopefully run on a lower spec’d system. This is not the case for v5 or older versions.
@stevefuchs Does this apply to anyone starting a new V9 evaluation, including those who don’t have a V8 license? If so it appears to be a change from the previous policy which required a V8 license to be able to run V7 or V6.
@davidcockey As long as the license is using our Cloud Zoo (Personal) licensing method, any V9 eval can also use V8 thru V6 for the eval licensing period. If you are using a Cloud Zoo (Personal) license method with a paid license, you can use the version you paid for and any previous version down to V6 without requesting a legacy license key for any previous versions. Hope that helps!
Not the same.
Thanks for the reply. That’s a fundamental change from the previous V8 system for which required all users to obtain a “Legacy Key” to run V7 or V6 (unless they also had V7 or V6 license) and was explicitly not supported for lab and evaluation licenses.
