Rhino V6 can't draw anything
I’ve recently installed Rhino V6 however I can’t seem to be able to draw anything and even after initiating a command it takes a long while for anything to be drawn. This is the system Info:
Rhino 6 SR17 2019-8-23 (Rhino 6, 6.17.19235.15041, Git hash:master @ 06b69c5cc21d880aa793a5a7cfd454a66f6213bb)
License type: Educational, build 2019-08-23
License details: Cloud Zoo. In use by: Elaine Stephen ()
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: DESKTOP-7IP01K3
Non-hybrid graphics.
Primary display and OpenGL: Intel® HD Graphics 4000 (Intel) Memory: 2GB, Driver date: 4-4-2016 (M-D-Y). OpenGL Ver: 4.0.0 - Build 10.18.10.4425
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.0
Shading Language: 4.00 - Build 10.18.10.4425
Driver Date: 4-4-2016
Driver Version: 10.18.10.4425
Z-Buffer depth: 24 bits
Total Video Memory: 2080 MB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.17.19235.15041
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.17.19235.15041
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.17.19235.15041
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.17.19235.15041
Hi Elaine - You will need to update the drivers of your GPU for this to work.
E.g. see this post:
Are there any applications you would recommend to update the GPU drivers?
The only application I would recommend is the Intel application. https://downloadcenter.intel.com/product/80939/Graphics-Drivers
If it does not work you may need to use the procedure described in Updating Intel HD Driver
