Please, check my post above. I just added a few bug reports there. The last one related to the inability to see a fully expanded floating panel upon clicking on a main toolbar icon is really disturbing. Rhino 7 shows the full set of icons, but Rhino 9 Beta doesn’t…
Also, the older bug that I reported a few weeks ago (shrinking the floating panels by one row after each opening) is still not resolved in the latest Beta. This forces the user to manually expand the floating panels again every time.
I released the mouse just a second after my initial dragging of the arrow handle upwards. The mouse pointer is still inside the viewport, near its center actually. This only happens in the latest Rhino 9 Beta. I noticed that this also happens every time after a LMB double-click on the arrow handle, but sometimes it happens even after holding the LMB (no double-click).
Upon a double-click the command line says “Gumbal Relocate”.
I wish that there is a new Rhino 7 version that consists just these few enhancements of Rhino 9:
“Patch”
Improved history for “Match surface”
“Global edge continuity”
“Elmo” (new “Curve rebuild”)
UVN Gumball
Static “Zebra”
Rhino 7 is extremely stable and polished, with perfect toolbar behaviour, no graphical bugs and instant switching of the display modes.
Hi @Rhino_Bulgaria , Match Studio looks great, especially the partial matching! Do you have an idea of when you plan to release it? And will it be available through the Rhino Package Manager or as a download on Food4Rhino?
Thanks, glad you like it! I started MatchStudio because the native Match is too limited - it doesn’t give you the freedom or the joy you want when modelling.
There’s no release date yet. Right now the focus is on getting it working properly and testing it on real projects, so things like the release date and how it will be distributed (Package Manager or Food4Rhino) haven’t been decided yet. I’ll post an update here when there’s more to share.
In my opinion, having the proper tools to control the overall flow of the surface is more important than the G3. The latter is often times too aggressive (just like G2) and may lead to some unwanted waviness affected by the adjacent target surface. This is where the loose G2 option of “Blend studio” shows its strength.
Also, both “Blend studio” and “Match studio” support a dozen of different ways to smooth out the middle portion of the surface, as well as drag mode for those who need a direct manual adjustment. The drag mode also supports an alternative, secondary slider for the normal direction (just like the “Drag strength” tool in Rhino 9).
“Match studio” lets you slide the edge to be matched along the target edge, as well as 4 different types of edge alignment. There is also a falloff option to gradually smooth out the remaining control points beyond the initial G1 or G2 rows that are matched to the target edge.
Fair point. G3 has its fans, and I won’t say it’s never useful. My own experience is different, though.
What makes a large blend look smooth, especially one with accelerating curvature, isn’t really the extra continuity order at the edge. It’s how the curvature is spread across the whole blend. With G2 plus one or two extra middle rows that you can actually control (bulge, position, per-column or point by point, with G1/G2 kept), you can shape that curvature ramp exactly the way you want, and the reflections come out just as clean as with G3. Small part or big one, it makes no difference.
G3 locks one more row to the neighbouring surface’s rate of curvature change. On paper it’s “more continuous”. In practice it’s one more constraint that’s hard to control and makes the surface heavier to work with than it needs to be. So for me it’s a bit overrated.
That said, I’d really like to see a case where you feel G3 is essential. If you can share one, I’m happy to try the same transition with G2 plus extra rows in BlendStudio and post the zebra / curvature comparison here. That would be a good test for both of us.
The situation is that I need to move all at once the upper and lower patch to the yellow one, so in Icem surf or Alias you have the option to deactivate the keep oppsite function, therefore you are able to move all the rows of the patch accordingly to the movement of the matching:
Thanks Jordi, good idea – I’ll add it to MatchStudio as an option you can switch on or off: with “none” and a factor, the whole patch follows the match. It’ll come in one of the next builds.
