Rhino.UI.Panels.OpenPanel(Type type) not working in Rhino 8
Hi there,
In Rhino 7 I use this code to check if my plugin panel is visible and make it visible when running a command:
 if (!Rhino.UI.Panels.IsPanelVisible(typeof(PanelCgWpf), true))
                    Rhino.UI.Panels.OpenPanel(typeof(PanelCgWpf));
but in Rhino 8 that doesn’t work, if it’s a bug could you please add it to the bug tracker.
Thank you and regards
Will
Hi @Harper,
Try using the override that requires a GUID.
If not, please provide a project sample that does not work for you.
Thanks,
– Dale
Hi Dale,
Thanks for you answer, I tried using the dockbar id where the panel is docked and it works, so problem solved.
Thank you again
Will
