Hi @dale,
i´ve found that if more than 30 lines of text are used in below code for the txt
variable:
Rhino.UI.Dialogs.ShowTextDialog(txt, "Output")
the output is an empty dialog. Does the text need some special linefeed formating for this to work ?
c.
dale
(Dale Fugier)
2
dale
(Dale Fugier)
3
Can you provide a more detailed example that doesn’t work for you?
Hi Dale, a quick one, my original seems to have longer lines, below fails with 150:
import Rhino
def DoSomething():
text_out = []
for i in xrange(150):
text_out.append(str(i) + " Hello Rhino")
txt = "\n".join(text_out)
Rhino.UI.Dialogs.ShowTextDialog(txt, "Title")
DoSomething()
btw. rs.TextOut()
seems to be missing in rhinoscript syntax. @Alain maybe this could be added ?
c.
dale
(Dale Fugier)
5
brian
(Brian Gillespie)
6
RH-33800 is fixed in the latest WIP
