Hey Developers,
has anyone had any success with Rhino.Testing in headed mode? I need to run my tests within an active GL context but can’t get it to activate even for the simplest task.
@CallumSykes, @sonderskovmathias can you help here?
[Warning] Frame 0: ViewCapture returned null.
[Warning] Frame 1: ViewCapture returned null.
[Sim Thread 27] Sim Running...
[Warning] Frame 2: ViewCapture returned null.
[Warning] Frame 3: ViewCapture returned null.
[Warning] Frame 4: ViewCapture returned null.
[Sim Thread 27] Sim Finished.
Sim and UI interaction completed.
<?xml version="1.0" encoding="utf-8"?>
<Settings>
<RhinoSystemDirectory>C:\Program Files\Rhino 8\System</RhinoSystemDirectory>
<LoadEto>true</LoadEto>
<LoadRDK>true</LoadRDK>
<CreateRhinoView>true</CreateRhinoView>
</Settings>
[TestFixture]
public class PoCTests
private void RunOnMainThread(System.Action action)
if (RhinoApp.InvokeRequired)
RhinoApp.InvokeOnUiThread(action);
else
action();
[Test]
public void SanityCheck_RhinoIsLoaded()
Assert.IsNotNull(RhinoDoc.ActiveDoc, "Rhino ActiveDoc should be available.");
TestContext.WriteLine($"Running inside Rhino Version: {RhinoApp.Version}");
[Test]
public void Test_SimAndUI_ThreadingCollision()
// Start a fake simulation on a background thread
var simTask = Task.Run(() =>
Thread.Sleep(100); // Simulate boot up
TestContext.WriteLine($"[Sim Thread {Thread.CurrentThread.ManagedThreadId}] Sim Running...");
// Simulate Native Work
for (int i = 0; i < 5; i++)
Thread.Sleep(50);
TestContext.WriteLine($"[Sim Thread {Thread.CurrentThread.ManagedThreadId}] Sim Finished.");
// While Sim is running, force UI/OpenGL access on Main Thread
RunOnMainThread(() =>
var view = RhinoDoc.ActiveDoc.Views.ActiveView;
if (view == null || !view.Floating)
view = RhinoDoc.ActiveDoc.Views.Add(
"TestView",
Rhino.Display.DefinedViewportProjection.Top,
new System.Drawing.Rectangle(0, 0, 800, 600),
true
view.Size = new System.Drawing.Size(800, 600);
RhinoDoc.ActiveDoc.Views.ActiveView = view;
view.Redraw();
var capture = new Rhino.Display.ViewCapture
Width = 800,
Height = 600,
DrawAxes = true,
DrawGrid = true,
TransparentBackground = false
using (var bitmap = capture.CaptureToBitmap(view))
if (bitmap != null)
string path = Path.Combine(TestContext.CurrentContext.WorkDirectory, $"frame_{i}.png");
bitmap.Save(path, System.Drawing.Imaging.ImageFormat.Png);
TestContext.WriteLine($"Saved frame to: {path}");
else
TestContext.WriteLine($"[Warning] Frame {i}: ViewCapture returned null.");
Thread.Sleep(60); // Wait between UI updates
// Wait for Sim to finish
simTask.Wait();
Assert.Pass("Sim and UI interaction completed.");
