I just installed the Rhino Sync plugin on my Mac, and I am running into a sequence of issues every time I try to connect to a model shared with me on Google Drive.
Initially, I am able to log into Google Drive and choose the shared file. Rhino Sync then redirects me from Chrome back to Rhino 8, but it gives me an error saying: “Read-only file system: ‘/Rhino.Sync’”. I realized that the plugin’s code appears to be attempting to write to the absolute root directory of the Mac (/Rhino.Sync) rather than the user directory (~/Rhino.Sync), which modern macOS blocks for security.
To try and fix this, I changed every file inside the package directory ~/Library/Application Support/McNeel/Rhinoceros/packages/8.0/RhinoSync to have read and write permissions, tried sharing the file to a different Google account, and even tried older versions of the plugin, but nothing worked. I was eventually able to temporarily bypass this read-only error by creating a virtual symbolic link at the root level (using synthetic.conf) to map /Rhino.Sync to a writable directory I created at /Users/Shared/Rhino.Sync.
However, while this successfully cleared the read-only error, it led to a new issue. Now, when the plugin attempts to connect to the shared file, it immediately crashes and throws this exception: “Object reference not set to an instance of an object.”
I have confirmed that I have full “Editor” access to the file on Google Drive, so it doesn’t appear to be a cloud permission issue. It seems the plugin is failing to initialize its required subdirectories or background files within that new path. For context, I tried switching to a Windows virtual machine, and the plugin works just fine there.
I have attached screenshots of both errors for your reference. Please let me know if you have any idea what is causing this sequence of errors and if there is a patch or specific workaround I should use for macOS.
Thank you!
