Hello, i am trying to render a house scene and i get a reflection light. I have turned off the rhino sun and dome light and for sure every other light i have is off but i still get the reflection. Does anybody know what i am doing wrong?
Thank you
If there is no Skylighting (with a sun dominating a lot of the HDRI), then you can also try the following chain:
Turn off Sun → Switch to Shaded → Switch to Raytraced.
Sometimes, Cycles fails to update lighting if you remain in Raytraced while making changes.
Probably not the problem, but always worth a try. But the change in tone inplies something has happened.
Beyond that, reduce your scene to a sphere and a cube, and a Ground Plane, and check it is reproducable with just these objects, no materials.
Oh, as normal, it typically helps to post your SystemInfo in the forum.
