Rhino suddenly running slow, viewports look bugged
My shaded and rendered viewports never look like this, and the osnaps look bugged because they’re squares and not circles. And everything is running slow.
I have a feeling this is something with my computer or graphics or something because photoshop is also suddenly running slow. I already tried updating my graphics driver, resetting, and resetting rhino cache.
This isnt the first time this has happened, but hours later or a shutdown later it would return to normal. But now it’s been staying like this for way too long.
Here’s the system info
Rhino 7 SR38 2024-12-3 (Rhino 7, 7.38.24338.17001, Git hash:master @ 97e36efa02d7f71638988290bb2d190fcf1b18c5)
License type: Educational, build 2024-12-03
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 32Gb)
Primary display and OpenGL: Microsoft Basic Display Adapter (Intel) Memory: 0MB, Driver date: 6-21-2006 (M-D-Y). OpenGL Ver: 1.1.0
Integrated graphics device with 1 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
Secondary graphics devices.
NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 12-11-2025 (M-D-Y).
Integrated accelerated graphics device with 4 adapter port(s)
  • This device is not being used
ATTENTION:
No graphics device is being used. Either an error occurred on startup, or certain devices have been disabled.
See below for any possible configuration changes that may help resolve this issue.
  • Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 0.0 (primary GPU’s maximum)
Anti-alias mode: None
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: 12-11-2025
Driver Version: 32.0.15.9159
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 8188 MB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.38.24338.17001
yep, your graphics drivers are messed up.
reinstall the intel and the nvida
use the intel update tool, not the device manager in windows,
this is the tell-
and
ATTENTION:
then grab a new driver for your nvida and install it using the custom install option. Choose “clean install”
restart your machine and try Rhino again.
also this thread may help-
still stuck? give us a call in tech support.
206-545-6877
