Quite often, when I am trying by pressing ‘del’ keystroke, it types ‘.’ in the command in Rhino and not actually deleting the component itself. The only solution for me so far is to restart the whole software.
Unfortunately, toggling numlock key on/off did not solve the problem.
When I highlight a grasshopper component and hit delete key, did does not delete the GH component but just typed ‘_Delete’ command in the command line.
I don’t know, maybe other GH users have had the same experience… Do you have any other programs running besides Rhino/Grasshopper? I have had other programs mess with key stroke acceptance in Rhino, like Photoshop… and even Acrobat recently.
Yes, the window is active and the component I want to delete is highlighted.
When I pressure the del key, the window becomes inactive and the Rhino’s window becomes active and _Delete command was shown on the command line.
FWIW, I’ve experienced this numerous times myself and seems to occur sometimes after using raytrace for rendering. Copy, Paste and Delete are affected and I must either use the GH menu commands or restart. It never just goes away on its own.
