Rhino Startup problems
since the latest Rhino6 WIP I get the following error message on start. When I start Rhino, it´s not responsive anymore.
Hi Detlef,
Were you having display problems in past WIPs? That dialog shouldn’t even display unless a test command was executed to turn it on.
Do you see this right when you start Rhino with an empty model?
Hi Steve,
No problems before this release. I did try a test command a while back. But don´t remember which one it was.
cheers,
Detlef
Hi Detlef,
Have you tried a recent WIP and if so does this problem still exist?
hi Steve,
no problem anymore. Thank you for asking again.
cheers,
Detlef
