I am working on scanned data (mesh) of around 39Mb, Rhino runs nice and smooth for a short period then becomes slow and starts loading for short time and then becomes Okay again.
I have disabled autosave and put mesh settings to fast.
Hi - please post the result of the Rhino SystemInfo
command.
What does that mean?
Rhino 6 SR21 2019-12-17 (Rhino 6, 6.21.19351.09141, Git hash:master @ 4d373f64ffb55e3a8d607d9618590728d86fb1e9)
License type: Evaluation, build 2019-12-17
License details: Cloud Zoo. In use by: Nassor Majeed ()
Expires on: 2020-04-05
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: PT-03048
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA Quadro K620 (NVidia) Memory: 2GB, Driver date: 12-6-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 441.66
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-6-2019
Driver Version: 26.21.14.4166
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.21.19351.9141
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.21.19351.9141
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Flamingo nXt 5.0 (fd53f8c4-546d-47d1-8820-e66c97645a97)\5.5.18100.1000\5.5\Legacy\Flamingo.Legacy.dll "Flamingo nXt Legacy File Reader " 5.5.18100.1000
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.21.19351.9141
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 6.21.19351.9141
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.21.19351.9141
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Flamingo nXt 5.0 (fd53f8c4-546d-47d1-8820-e66c97645a97)\5.5.18100.1000\5.5\Flamingo.nXt.rhp “Flamingo nXt 5.5” 5.5.18100.1000
Hi Nassor - Thanks for that.
- is the 39 MB file a 3dm file or is that the size of the imported file?
- Can you attach a file?
- I still don’t know what “[…] and starts loading for short time […]” means
When you only have mesh objects in your scene, changing the mesh settings won’t do anything.
Sorry I cannot attach the file but it is an OBJ file from a 3d scan. What that means is it works fine for a short time then stops working or works really slow. When it stop working the mouse shows the loading(turning) wheel.
I hope that clarifies.
Thank you.
Any Update?
Thanks.
Hi - without a file, it’s hard to try to reproduce things. Is it possible to share it with McNeel? If so, you can upload it on the following page - make sure to add the URL to this discussion in the comments field.
https://www.rhino3d.com/upload
Apart from that, have you tried running Rhino in safe mode to check if the issue persists?
Yes I did try safe mode and there was no difference.
I have uploaded the file to the page you gave me. It is a much bigger file than the one before but I am also using another System that I believe is able to handle such a file. Here are the system specspc spec .txt (1.7 KB)
Thank you.
Hello - I see some problems opening your file as well - I don’t yet have a good idea what but Check
does not like it at all so far.
Hm - well, it is 10 million vertices…
@nassor1738 - one thing to try is to SplitDisjointMesh
- wait for that to happen (go get a coffee) and then go around and selectively rejoin parts or delete them, move to different layers, etc so that you can deal with a subset of the mesh at a time rather than all 10 million vertices.
