I feel like there was a feature that I can snap while moving an object with left hold click. For example you click and hold a corner of a box with left mouse button (even though I dont click exactly in the corner, Rhino will click where the snapping is on), and I drag it to an object, then it will snap to end, mid, center or whatever I turned the snapping on even before I release the left button. Does such feature exist?
Yep. It works just as you said. Just have to first select the object, then hold the LMB down near the snap point on the object you want. The object snap will light up, then drag the object and snap it somewhere else.
ohhh I realized I did not press long enough, now I see the snapping option!! jesus christ if I were a little more patient, I could’ve saved a few years of time manually moving… thank you so much!!
