Hello - I’m afraid there is not an equivalent in V5, that I know of.
this helped INCREDIBLY. Reduced from 1 minute to 3 seconds. I pity all the time waiting for savings just for the sake of megabytes. damn that program.
in 2021, i still have this problem. 100mb file saves in seconds locally, can copy to server in seconds, but if I save directly to the server it takes several minuttes. Something is off. Just tried to disable compression, which made it even slower…
@pascal any news on this issue in V7/8?
Hi Mathias -
Are you using the WriteLocalTempFileWhenSaving=True
option in the advanced settings?
If you’re issue is related to network saving, there’s a separate thread for that:
This was false.
Thank you, now save times went from 5 mins to 10-15 secs with compression and 8-10 secs without!
Any chance of getting access to this through RhinoCommon at some point?
The closest i got was this enum. but where is it used…
This worked for me. Reduced save time from about 4 minutes to 1.5. (also doubled the file size). But totally worth it.
@sonderskovmathias Yeah was hoping it would be added to the ApplicationSettings part like the PackageManagerSettings is.
@wim any chance of this or does it have to be done through the AdvancedSetting Enumeration?
Edit: Found a way to access it through the PersistentSettings Class:
Rhino.PersistentSettings RhFilesettings = Rhino.PlugIns.PlugIn.GetPluginSettings(Rhino.RhinoApp.CurrentRhinoId, false).GetChild("Options").GetChild("FileSettings");
if(!RhFilesettings.GetBool("WriteLocalTempFileWhenSaving"))
RhFilesettings.SetBool("WriteLocalTempFileWhenSaving", true);
Rhino.PlugIns.PlugIn.SavePluginSettings(Rhino.RhinoApp.CurrentRhinoId);
This worked from me, from 1 min to 5 sec
Rhino.Options.FileSettings.WriteLocalTempFileWhenSaving
Worked for us, we went from 84Mbps upload to the DFS, to 800Mbps uploads.
Thanks!
