Rhino Skin Issue
Hello Everbody,
Recently this problem appeared to load our Rhino Plug-In in Windows with non-English language,
It seems an issue with a FontFamily,
Applying this method is not effective for us…
Start > Control Panel > Administrative Tools > Services (or type services.msc from the Run command box).
Stop the Windows Presentation Foundation Font Cache 3.0.0.0 service.
Delete the cache file: FontCache3.0.0.0.dat
WinXP: C:\Documents and Settings\LocalService\Local Settings\Application Data
Vista/Win7: C:\Windows\ServiceProfiles\LocalService\AppData\Local
Restart the service or reboot the computer.
Do you know any news about this issue?
Thank you very much for your attention
Josep Rexach
System.Windows.Threading.Dispatcher.CurrentDispatcher.UnhandledException
SENDER: System.Windows.Threading.Dispatcher
EXCEPTION: System.NullReferenceException
MESSAGE: Object reference not set to an instance of an object.
SOURCE: “PresentationCore”
CALL STACK
at System.Windows.Media.FontFamily.LookupFontFamilyAndFace(CanonicalFontFamilyReference canonicalFamilyReference, FontStyle& style, FontWeight& weight, FontStretch& stretch)
at System.Windows.Media.FontFamily.FindFirstFontFamilyAndFace(FontStyle& style, FontWeight& weight, FontStretch& stretch)
at System.Windows.Media.Typeface.ConstructCachedTypeface()
at System.Windows.Media.Typeface.get_CachedTypeface()
at System.Windows.Media.Typeface.CheckFastPathNominalGlyphs(CharacterBufferRange charBufferRange, Double emSize, Single pixelsPerDip, Double scalingFactor, Double widthMax, Boolean keepAWord, Boolean numberSubstitution, CultureInfo cultureInfo, TextFormattingMode textFormattingMode, Boolean isSideways, Boolean breakOnTabs, Int32& stringLengthFit)
at MS.Internal.TextFormatting.SimpleRun.CreateSimpleTextRun(CharacterBufferRange charBufferRange, TextRun textRun, TextFormatterImp formatter, Int32 widthLeft, Boolean emergencyWrap, Boolean breakOnTabs, Double pixelsPerDip)
at MS.Internal.TextFormatting.SimpleRun.Create(FormatSettings settings, CharacterBufferRange charString, TextRun textRun, Int32 cp, Int32 cpFirst, Int32 runLength, Int32 widthLeft, Int32 idealRunOffsetUnRounded, Double pixelsPerDip)
at MS.Internal.TextFormatting.SimpleTextLine.Create(FormatSettings settings, Int32 cpFirst, Int32 paragraphWidth, Double pixelsPerDip)
at MS.Internal.TextFormatting.TextFormatterImp.FormatLineInternal(TextSource textSource, Int32 firstCharIndex, Int32 lineLength, Double paragraphWidth, TextParagraphProperties paragraphProperties, TextLineBreak previousLineBreak, TextRunCache textRunCache)
at MS.Internal.TextFormatting.TextFormatterImp.FormatLine(TextSource textSource, Int32 firstCharIndex, Double paragraphWidth, TextParagraphProperties paragraphProperties, TextLineBreak previousLineBreak, TextRunCache textRunCache)
at System.Windows.Controls.TextBlock.MeasureOverride(Size constraint)
at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
at System.Windows.UIElement.Measure(Size availableSize)
at System.Windows.Controls.AccessText.MeasureOverride(Size constraint)
at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint)
at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint)
at System.Windows.Controls.Border.MeasureOverride(Size constraint)
at System.Windows.Controls.Control.MeasureOverride(Size constraint)
at Eto.Wpf.Forms.WpfFrameworkElement3.MeasureOverride(Size constraint, Func2 measure) in D:\BuildAgent\work\commercial\src4\DotNetSDK\Eto\src\Eto.Wpf\Forms\WpfFrameworkElement.cs:line 109
at Eto.Wpf.Forms.Controls.EtoLabel.MeasureOverride(Size constraint) in D:\BuildAgent\work\commercial\src4\DotNetSDK\Eto\src\Eto.Wpf\Forms\Controls\LabelHandler.cs:line 23
at System.Windows.Controls.Grid.MeasureCell(Int32 cell, Boolean forceInfinityV)
at System.Windows.Controls.Grid.MeasureCellsGroup(Int32 cellsHead, Size referenceSize, Boolean ignoreDesiredSizeU, Boolean forceInfinityV, Boolean& hasDesiredSizeUChanged)
at System.Windows.Controls.Grid.MeasureOverride(Size constraint)
at Eto.Wpf.Forms.EtoGrid.MeasureOverride(Size constraint) in D:\BuildAgent\work\commercial\src4\DotNetSDK\Eto\src\Eto.Wpf\Forms\TableLayoutHandler.cs:line 16
at Eto.Wpf.Forms.WpfContainer3.MeasureOverride(Size constraint, Func2 measure) in D:\BuildAgent\work\commercial\src4\DotNetSDK\Eto\src\Eto.Wpf\Forms\WpfContainer.cs:line 47
at Eto.Wpf.Forms.EtoBorder.MeasureOverride(Size constraint) in D:\BuildAgent\work\commercial\src4\DotNetSDK\Eto\src\Eto.Wpf\Forms\EtoBorder.cs:line 24
at System.Windows.Controls.ScrollContentPresenter.MeasureOverride(Size constraint)
at System.Windows.Controls.ScrollViewer.MeasureOverride(Size constraint)
at Eto.Wpf.Forms.Controls.ScrollableHandler.EtoScrollViewer.MeasureOverride(Size constraint) in D:\BuildAgent\work\commercial\src4\DotNetSDK\Eto\src\Eto.Wpf\Forms\Controls\ScrollableHandler.cs:line 31
at System.Windows.Controls.DockPanel.MeasureOverride(Size constraint)
at System.Windows.Documents.AdornerDecorator.MeasureOverride(Size constraint)
at System.Windows.Window.MeasureOverrideHelper(Size constraint)
at System.Windows.Window.MeasureOverride(Size availableSize)
at System.Windows.Interop.HwndSource.SetLayoutSize()
at System.Windows.Interop.HwndSource.set_SizeToContent(SizeToContent value)
at System.Windows.Window._OnSizeToContentChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
at System.Windows.Window.set_SizeToContent(SizeToContent value)
at Eto.Wpf.Forms.WpfWindow`3.b__23_0(Object , RoutedEventArgs ) in D:\BuildAgent\work\commercial\src4\DotNetSDK\Eto\src\Eto.Wpf\Forms\WpfWindow.cs:line 84
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.BroadcastEventHelper.BroadcastEvent(DependencyObject root, RoutedEvent routedEvent)
at System.Windows.BroadcastEventHelper.BroadcastLoadedEvent(Object root)
at MS.Internal.LoadedOrUnloadedOperation.DoWork()
at System.Windows.Media.MediaContext.FireLoadedPendingCallbacks()
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
at System.Windows.Interop.HwndTarget.OnResize()
at System.Windows.Interop.HwndTarget.HandleMessage(WindowMessage msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Interop.HwndSource.HwndTargetFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHa
In case anyone else notices this issue with other plugins or skins, this appeared to be a race condition deep in WPF’s code.
Adding this to the skin constructor appears to fix the issue:
System.Windows.SystemFonts.MessageFontFamily.GetTypefaces();
This fix will also be in Rhino 6.12.
RH-48315 is fixed in the latest Service Release
