Rhino > Sketchup 2018
Hi @pascal et al,
Do we have any news about getting geometry from Rhino (v6 or otherwise) to Sketchup? Best I can do from the date of this writing 03/03/18 is:
DXF 2004 Solids: This is good going into SKP, b/c a 6-sided solid cube comes in as a group with connected faces. Apparently though, my SKP expert friend says he cannot make this geometry into Components within SKP, which is troublesome.
Export/SaveAs .skp file: Works great for Blocks, as they keep layers and are nested within components, etc in SKP. But a 6-sided Solid cube comes in as separate faces. Not good.
That’s the same as what I could find in a thread from 2015.
So, any news on this front?
@pascal @nathanletwory Hey guys, figured I’d ping this. Almost exactly 3 years later to the day and I’m looking up the same exact question :crazy_face:
Any newfound glory? Without Blocks to SKP, it’s wonderfully light, but exploded. With Blocks to SKP, it’s grouped, but heavy as all heck.
EDIT: Ah finally remembered that if you have sketchup pro you can import the dwg/dxf 2007 solids.
