Hi I’m new to rvb scripting and I am trying to get Rhino5 to open a file with out having to press enter at the command line.
here is my problem code taken from existing examples:
Dim strFile
strFile = "C:\Users\david000\Desktop\SHEETCAM JOBS\TORTOISE\MESHCAM\tortoise.stl"
strFile = Chr(34) & strFile & Chr(34) ' add the needed quote characters.
Call Rhino.DocumentModified(False) 'so you dont have to be asked to save old work
Call Rhino.Command("_-Open " & strFile, 0)
This works fine up to the point where I am asked to accept the following command line arguments by pressing enter.
After pressing enter , the file loads perfectly.
’ the command line: Set STL import options ( Weld=Yes WeldAngle=22.5 SplitDisjointMeshes=No ModelUnits=Millimeters ):
How do I get the open command to just accept these values as default. What is the syntax to include them in my script?
Thanks
David
