Rhino.Runtime.NotLicensedException reading document as launch argument
Hi all,
I have a problem with a c# plugin. I need to do some computation while reading a document. If I open a file after Rhino is loaded or from the splash screen everything works, but if I start Rhino7 double-clicking a file a Rhino.Runtime.NotLicensedException is thrown on first call to AreaMassProperty.Compute. I tried the same approach on a different PC and the same problem happens on RhinoMath.UnitScale.
This worked in Rhino6, but happens on every version of Rhino7.
Any idea?
Thanks,
Marco
Anyone has a solution here? I still have the problem calling AreaMassProperties.Compute while starting Rhino from a file. Only happens in Rhino7.
Thanks
I happens to me to, on a different method but same exception.
Same problem here. Hope this will be fixed soon.
I believe this is fixed in the 7.5 Release Candidate:
Thank you @brian, seems to work now! I’ll keep you posted if it happens again.
