Rhino.Runtime.HostUtils: receiver component question
Hello
How to assign “a self guid” to the receiver component to prevent other copies from receiving data?
rir.gh (3.7 KB)
I think you can by creating a receiver object (as in OOP object) that generates an id for each instance, which can imo be a simple counter.
Thanks @Gijs
I don’t understand your solution, actually i used enable condition to prevent new component from working but the user need only one in the canvas, it’s just in case when it added by fault
Hey! @anon39580149, @Gijs, I’m new with C# and I was trying to create a sender component to a clustered receiver, can anyone help me please?
Sender:
using System;
using Grasshopper.Kernel;
public class SenderComponent : GH_Component
    public SenderComponent() : base("Sender", "S", "Send numeric data to receiver", "Test", "Data") { }
    protected override void RegisterInputParams(GH_InputParamManager pManager)
        pManager.AddNumberParameter("Data", "D", "Numeric data to send", GH_ParamAccess.item);
    protected override void RegisterOutputParams(GH_OutputParamManager pManager) { }
    protected override void SolveInstance(IGH_DataAccess DA)
        double data = 0;
        if (!DA.GetData(0, ref data)) return;
        // Get the nickname of the target receiver
        string targetNickname = "ReceiverNickname";
        // Find the remote component with the given nickname within the cluster
        GH_Component targetComponent = null;
        foreach (IGH_DocumentObject obj in OnPingDocument().Objects)
            if (obj is GH_Cluster)
                GH_Cluster cluster = obj as GH_Cluster;
                foreach (IGH_Component clusterComponent in cluster.ClusterObjects(true))
                    if (clusterComponent.NickName == targetNickname && clusterComponent is GH_Component)
                        targetComponent = clusterComponent as GH_Component;
                        break;
        // Check if the target component was found
        if (targetComponent != null)
            // Send data to the target component
            targetComponent.Params.Input[0].AddVolatileData(new GH_Path(0), 0, data);
        // Expire solution to update the changes
        ExpireSolution(true);
    public override Guid ComponentGuid
        get { return new Guid("GUID_HERE"); }
Receiver:
using System;
public class ReceiverComponent : GH_Component
    public ReceiverComponent() : base("Receiver", "R", "Receive numeric data from sender", "Test", "Data") { }
    protected override void RegisterInputParams(GH_InputParamManager pManager) { }
        pManager.AddNumberParameter("Data", "D", "Received numeric data", GH_ParamAccess.item);
        double data = 0;
        // Receive data from the sender component
        DA.GetData(0, ref data);
        // Do something with the received data...
        // Output the received data
        DA.SetData(0, data);
    public override bool Read(GH_IReader reader)
        // Perform any additional reading here if needed
        return base.Read(reader);
    public override bool Write(GH_IWriter writer)
        // Perform any additional writing here if needed
        return base.Write(writer);
    protected override void ExpireDownStreamObjects()
        // Expire downstream objects to trigger a re-computation when data is received
        OnPingDocument().NewSolution(true);
        base.ExpireDownStreamObjects();
Thanks!
