Rhino just deleted all my aliases and reset settings to factory defaults. I had about six separate Rhino instances open and had just imported a pdf page into an unsaved file (I had previously imported several other pages from the same pdf into this file without problems).
At least these settings were reset:
Aliases
Application color settings
Custom display modes (it seems the custom modes may still exist, but were renamed to one of the factory default modes? I now have four copies of “wireframe”, two copies of “ghosted” etc.)
Right container switched from “horizontal” to “vertical” stacked panes
Toolbar layout seems to be unaffected, and 3D mouse macros remain (though any aliases they called have been lost).
Much, if not all, of this was rewritten for Rhino 9.
Unless you have a way to reliably reproduce this behavior in the current version of Rhino 8 (that is, SR35), I’m afraid this is not something that will get fixed.
Do you tend to have 6 rhinos open at one time? I wonder if there is a change in the settings that could have been coming from multiple rhinos at the same time.
In my experience it doesn’t matter how many rhino windows are open.
Sometimes it happened between a restart of Rhino (Saving a file, closing the program and then opening Rhino again)
A few times it happened without the program being closed, but simply being changed when ever I have had other programs in the front.
I did the post that @Measure quoted in the beginning so I am listening closely here.
