But in such a case, is way to keep mouse not freezing 1)putting more RAM?
2)or Limiting the thread in rhino render?
3)perhaps the new battery bar in windows impacts alot now? using laptop and setting to better battery at the moment.
Hello - see Options > Rhino Render Options page - you can limit the number of threads there as well as priority. I see mine is set to 7, so I must have seen something like what you’re reporting.
Thank you. I’ll set that. Tho I feel maybe it should be fixed somehow…
If adding more RAM helps I also like to consider that as an option. Do you know if it’ll help or is it more on CPU related?
