Rhino Raytraced View Mode Not Recognizing WIndow Glass as Separate material from other window elements
It’s not working for me either. This test was from a new visualarq template.
@djhg @arcus are you using WCS materials? Unfortunately, Enscape doesn’t work well with WCS materials from Rhino. This is something that happens with Rhino geometry and also affects VisualARQ objects. Unfortunately, we can’t help it.
This has been reported on the Enscape Forum: no wcs mapping in enscape? - Rhino - Enscape Community Forum
If you are not using WCS materials but just textures with a texture mapping applied, then please share the files so we will take a look, because this should work properly.
I see. I was under the impression the update applied to WCS materials. I generally try to avoid using mapped materials scales since it becomes tedious to keep them all updated. I’ll give it a try to the mapped materials.
I’ve noticed the WCS mapping appears to work well with D5 realtime renderer.
