Rhino Plugin installer question
Thanks in advance, we made a Rhino plugin, and want to add it into our own installer, any suggession how to do that, and where the dll should be copied to and registered. Thanks a lot.
The file we have now are:
  1. plmcPlugin.dll
  2. plmcPlugin.rui
  3. and some depending dlls.
  4. No .rhp file, what is the .rhp file, where can we found it? Thanks!
Thanks, I found the below two links, they are very helpful, so, only one question left: where is the .rhp file, it seems we don’t have one in the build files. Thanks a lot!
Hey @Robin,
You need to rename your plmcPlugin.dll as plmcPlugin.rhp once the build is finished.
If you’re using an SDK style project you can use this in your .csproj
    <PropertyGroup>
        <RootNamespace>plmc.Plugin</RootNamespace>
        <TargetFramework>net48</TargetFramework>
        <AssemblyTitle>plmcPlugin</AssemblyTitle>
        <AssemblyName>plmcPlugin</AssemblyName>
        <Nullable>annotations</Nullable>
        <LangVersion>8.0</LangVersion>
        <TargetExt>.rhp</TargetExt>
        <Platforms>x64</Platforms>
    <PropertyGroup>
Or you can use a build event like so
Copy "$(TargetPath)" "$(TargetDir)$(ProjectName).rhp"
Erase "$(TargetPath)"
Got it, Thanks a lot!
One more question, if I set up the registry like the below, the MySamplePlugin.Rui UI file which was under the same directory, will be automatically load either? Thanks!
Got it, Thanks Dale!
