Hi there,
I am doing some testing using CustomObject
called via plug-in and I am facing two problems:
If I stretch the geometry (line) using the grips after the modification is executed, it lost the selection on the grip.
I am using CustomCurveObject
, and the OnDraw
displays an extruded beam.
But when I select the geometry the visualization change.
What I should change to control this behavior?
Thanks
dale
(Dale Fugier)
July 19, 2021, 9:14pm
2
Hi @bianchini ,
You might consider just tagging the Rhino curve with some unique user data that identifies it as a “beam”. Then create a display conduit that looks for these objects and draws them accordingly.
– Dale
Hi @dale
so are you suggesting instead of using the CustomCurveObject
to move the actual logic and the display visualization into an UserData
dale
(Dale Fugier)
July 20, 2021, 3:15pm
4
Hi @bianchini ,
Custom object support in RhinoCommon is not as robust as it is in C++. In most cases, doing what I described above is a better approach.
– Dale
