Im having random error popups when trying to open multiple files in rhino. These are small files (28k) consisting of curves only. The file not loading is rdk_ui.rhp.
Seems to be a conflict between the DWG file load and the Plugin. Only happens when loading multiple files from Explorer (4 or 5 at a time).
Have been working around this for about 2 years now and thought I’d ask if maybe there is a solution?
My guess is loading the additional files/instances one at a time will avoid the problem.
If the timers are stretched out to wait longer, then every Rhino instance would take longer to load. Probably not the best option.
Yes, after editing, the files are reviewed in groups. Usually 4 or 5 are selected and “opened in Rhino” from Explorer. Works fine about 50% of the time depending on the file size. It most definitely feels like a “timing” issue when it doesn’t work. Im sure it would be easy to replicate the error as it is very consistent on this end.
One observation that might be of value. I never see the load error at the start of each day (cold reboot). It starts happening after the 2nd+ attempt at opening multiple files (of the day). Memory leak maybe?
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P2000 (NVidia) Memory: 5GB, Driver date: 2-10-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 511.79
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-10-2022
Driver Version: 30.0.15.1179
Z-Buffer depth: 24 bits
Total Video Memory: 5 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.4\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.6.4.0
\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
