Rhino pipe command
Hi all I am just beginning, could anyone explain how this pipe with varying diameter was modelled?
varying dia pipe.3dm (188.3 KB)
did you at least try the command already before posting? it really is not that difficult.
create you center curve around which the pipe will revolve around. then use the command Pipe with cap set to round, then you make the radii on the 2 ends first, after that you can add more radii by clicking on the curve and pull the radius out, do that as often as needed, maybe try with 3-4 different spots, where its thickest you create a bigger radius at the end points obviously smaller radii.
