Hello…
i found in forum the printer command, but if I call Rhino PDF as printer name, it doesn’t work…
i need a script that when i run it it print the rhino window in Pdf AND a picture with “rhino PDF” and “image file”
Hello…
is it possible?
Hi @onlyforpeace,
It doesn’t look like it. I’ve logged the issue so we can investigate.
https://mcneel.myjetbrains.com/youtrack/issue/RH-61278
– Dale
the two lines below doesn’t run:
fichier image and Rhino PDF
